Introducción
This is a replacement guide for the Cirago M9030 Cover. The following steps will guide you in the dismantling and rebuilding of the cover as well as a replacement.
Qué necesitas
Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
In order to reassemble your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
