Saltar al contenido principal
Cineyo BT-03 Device Page Button Replacement
Qué necesitas
  1. Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: paso 1, imagen 1 de 3 Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: paso 1, imagen 2 de 3 Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: paso 1, imagen 3 de 3
    • Remove the top (button side) rubber cover using your hands.
  2. Cineyo BT-03 Device Page Button Replacement: paso 2, imagen 1 de 2 Cineyo BT-03 Device Page Button Replacement: paso 2, imagen 2 de 2
    • Flip over the device and remove the bottom rubber cover using your hands.
  3. Cineyo BT-03 Device Page Button Replacement: paso 3, imagen 1 de 3 Cineyo BT-03 Device Page Button Replacement: paso 3, imagen 2 de 3 Cineyo BT-03 Device Page Button Replacement: paso 3, imagen 3 de 3
    • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
  4. Cineyo BT-03 Device Page Button Replacement: paso 4, imagen 1 de 3 Cineyo BT-03 Device Page Button Replacement: paso 4, imagen 2 de 3 Cineyo BT-03 Device Page Button Replacement: paso 4, imagen 3 de 3
    • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
    • The cover should remain as one solid piece.
  5. Cineyo BT-03 Device Page Button Replacement: paso 5, imagen 1 de 1
    • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
  6. Cineyo BT-03 Device Page Button Replacement: paso 6, imagen 1 de 1
    • Gently pull apart the two sections of the device.
  7. Cineyo BT-03 Device Page Button Replacement, Button: paso 7, imagen 1 de 2 Cineyo BT-03 Device Page Button Replacement, Button: paso 7, imagen 2 de 2
    • With a Phillips #1 screwdriver, remove the two 5mm screws which attach the button mount to the plastic casing of the device.
  8. Cineyo BT-03 Device Page Button Replacement: paso 8, imagen 1 de 2 Cineyo BT-03 Device Page Button Replacement: paso 8, imagen 2 de 2
    • Using a plastic opening tool, pry the button mount off of the plastic casing of the device.
  9. Cineyo BT-03 Device Page Button Replacement: paso 9, imagen 1 de 2 Cineyo BT-03 Device Page Button Replacement: paso 9, imagen 2 de 2
    • Using a soldering iron and iFixit’s Soldering Guide, remove the individual buttons.
Conclusión
Rene Klopf
Miembro Desde 01/30/17
463 Reputación
4 Guías creadas
Equipo
Baylor, Team 8-3, Whitney Spring 2017 Miembro de Baylor, Team 8-3, Whitney Spring 2017
BU-WHITNEY-S17S8G3
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 118
