Saltar al contenido principal
Chumby One Motherboard Replacement
Qué necesitas
  1. Chumby One Motherboard Replacement, Chassis: paso 1, imagen 1 de 1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One Motherboard Replacement: paso 3, imagen 1 de 1
    • Remove the back and bottom cover.
  4. Chumby One Motherboard Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One Motherboard Replacement: paso 5, imagen 1 de 1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the inner components from the outer shell.
  10. Chumby One Motherboard Replacement, Motherboard: paso 10, imagen 1 de 1
    • Remove the speaker connector using a plastic spudger.
  11. Chumby One Motherboard Replacement: paso 11, imagen 1 de 1
    • Remove the Chumby button connector using a plastic spudger.
  12. Chumby One Motherboard Replacement: paso 12, imagen 1 de 1
    • Remove three 6mm screws using a PH000 bit.
  13. Chumby One Motherboard Replacement: paso 13, imagen 1 de 1
    • Remove the motherboard by pulling straight away from the housing.
    • Removing the motherboard there are 2 pins and socket connectors that may cause injury.
Conclusión
Jordan Houchins
Miembro Desde 03/27/17
401 Reputación
4 Guías creadas
Equipo
IUPUI, Team S3-G3, Baechle Spring 2017 Miembro de IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 253
