Saltar al contenido principal
Chumby One LCD Screen Replacement
Qué necesitas
  1. Chumby One LCD Screen Replacement, Chassis: paso 1, imagen 1 de 1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One LCD Screen Replacement: paso 3, imagen 1 de 1
    • Remove the back and bottom cover.
  4. Chumby One LCD Screen Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One LCD Screen Replacement: paso 5, imagen 1 de 1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One LCD Screen Replacement: paso 6, imagen 1 de 1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One LCD Screen Replacement: paso 7, imagen 1 de 1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One LCD Screen Replacement: paso 8, imagen 1 de 1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One LCD Screen Replacement: paso 9, imagen 1 de 1
    • Remove the inner components from the outer shell.
  10. Chumby One LCD Screen Replacement, LCD Screen: paso 10, imagen 1 de 1
    • Remove the four 5.5mm screws with a Phillips PH000 screwdriver bit.
  11. Chumby One LCD Screen Replacement: paso 11, imagen 1 de 1
    • Remove the metal shield from the front case using a plastic opening tool.
  12. Chumby One LCD Screen Replacement: paso 12, imagen 1 de 1
    • Remove the LCD screen from the outer case using a plastic opening tool.
Conclusión
Jordan Houchins
Miembro Desde 03/27/17
401 Reputación
4 Guías creadas
Equipo
IUPUI, Team S3-G3, Baechle Spring 2017 Miembro de IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 185
