Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Chrysler Pacifica 2004 Water Pump Replacement
Qué necesitas
    • Disconnect battery cables from battery posts.
    • Safely Jack up car to remove the passenger side front tire.
    • Remove splash guard in wheel well by removing Phillips head screws around parameter and a few plastic clips.
    • unscrew one fastener and disconnect any hoses to the engine.
    •  two additional 'push-on' connecting points on the underside.
    •  disconnect the baffles to the intake manifold(optional but makes much needed room)
    • Remove sensor on the baffles which can be pulled off by first sliding a red tab on the electrical connection.
    • Unscrew the white knob on the driver side bottom of the radiator.
    • Remove fill cap to allow for quicker drain
    • Some people will remove the engine fan to allow for more working space.
Conclusión
4 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 35
Todo El Tiempo: 6,310
