Saltar al contenido principal
Chromo Noria Battery Replacement
Qué necesitas
  1. Chromo Noria Battery Replacement, Back Panel: paso 1, imagen 1 de 3 Chromo Noria Battery Replacement, Back Panel: paso 1, imagen 2 de 3 Chromo Noria Battery Replacement, Back Panel: paso 1, imagen 3 de 3
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Battery Replacement: paso 2, imagen 1 de 1
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Battery Replacement, Battery: paso 3, imagen 1 de 3 Chromo Noria Battery Replacement, Battery: paso 3, imagen 2 de 3 Chromo Noria Battery Replacement, Battery: paso 3, imagen 3 de 3
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
  4. Chromo Noria Battery Replacement: paso 4, imagen 1 de 3 Chromo Noria Battery Replacement: paso 4, imagen 2 de 3 Chromo Noria Battery Replacement: paso 4, imagen 3 de 3
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
  5. Chromo Noria Battery Replacement: paso 5, imagen 1 de 1
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
Conclusión
Una persona más ha completado esta guía.
Kevin Nguyen
Miembro Desde 10/31/16
159 Reputación
1 Guía escrita
Equipo
Baylor, Team 5-6, Williams Fall 2016 Miembro de Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 504
