Saltar al contenido principal
Chromo Inc. T2 Internal Speaker Replacement
Qué necesitas
  1. Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: paso 1, imagen 1 de 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: paso 1, imagen 2 de 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: paso 1, imagen 3 de 3
    • Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Internal Speaker Replacement, Turn it around: paso 2, imagen 1 de 1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: paso 3, imagen 1 de 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: paso 3, imagen 2 de 3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: paso 3, imagen 3 de 3
    • Remove two strips of tape: One holding down the wires and the other holding down the internal speaker.
  4. Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: paso 4, imagen 1 de 3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: paso 4, imagen 2 de 3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: paso 4, imagen 3 de 3
    • Using a Soldering Iron, desolder both speaker wires. Once both wires are desoldered, your Internal Speaker is now ready for replacement!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
Conclusión
Ismael DeLuna
Miembro Desde 01/21/15
637 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 15-1, Watkins Winter 2015 Miembro de USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 217
