Saltar al contenido principal
Chromecast Power Button Replacement
Qué necesitas
  1. Chromecast Power Button Replacement, Case: paso 1, imagen 1 de 1
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Chromecast Power Button Replacement: paso 2, imagen 1 de 1
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Chromecast Power Button Replacement: paso 3, imagen 1 de 1
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Chromecast Power Button Replacement: paso 4, imagen 1 de 1
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Chromecast Power Button Replacement: paso 5, imagen 1 de 2 Chromecast Power Button Replacement: paso 5, imagen 2 de 2
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
  6. Chromecast Power Button Replacement, Power Button: paso 6, imagen 1 de 1
    • Press the plastic button from the outside of the port, pushing it inward if it is stuck.
Conclusión
2 personas más completaron esta guía.
Cameron Heiges
Miembro Desde 03/21/18
680 Reputación
3 Guías creadas
Equipo
IUPUI, Team S5-G6, Baechle Spring 2018 Miembro de IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 969
