Saltar al contenido principal
Chromebook Pixel (2013) Battery Replacement
Qué necesitas
  1. Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: paso 1, imagen 1 de 2 Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: paso 1, imagen 2 de 2
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: paso 2, imagen 1 de 3 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: paso 2, imagen 2 de 3 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: paso 2, imagen 3 de 3
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Chromebook Pixel (2013) Battery Replacement, Pop it open: paso 3, imagen 1 de 2 Chromebook Pixel (2013) Battery Replacement, Pop it open: paso 3, imagen 2 de 2
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): paso 4, imagen 1 de 2 Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): paso 4, imagen 2 de 2
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
  5. Chromebook Pixel (2013) Battery Replacement, Remove the bottom cover: paso 5, imagen 1 de 1
    • You should have your Chromebook Pixel flipped over and the bottom cover removed at this point
  6. Chromebook Pixel (2013) Battery Replacement, Release the battery: paso 6, imagen 1 de 1
    • Remove the screws holding the battery in place.
  7. Chromebook Pixel (2013) Battery Replacement, Unplug the battery: paso 7, imagen 1 de 2 Chromebook Pixel (2013) Battery Replacement, Unplug the battery: paso 7, imagen 2 de 2
    • Using a splunger or your finger and a gentle pull, unplug the battery from the Pixel logic board
    • Pull the battery toward you to remove it
  8. Chromebook Pixel (2013) Battery Replacement, Examine the new battery: paso 8, imagen 1 de 1
    • Make sure that the wattage and voltage matches the values of the old battery
  9. Chromebook Pixel (2013) Battery Replacement, Install the new battery: paso 9, imagen 1 de 2 Chromebook Pixel (2013) Battery Replacement, Install the new battery: paso 9, imagen 2 de 2
    • Follow these steps in reverse and turn on the Pixel.
    • If the old battery was failing, will have to reset the system time when you log back into Chrome OS or your installed Operating System
Conclusión
8 personas más completaron esta guía.
Kevin Fessler
Miembro Desde 04/16/16
1,773 Reputación
4 Guías creadas
2 comentarios
You can now find these batteries on Amazon too- just search for the same part number GP-S22-000000-0100
riansanderson - Contestar
Hello could someone help
Where would i get a replacement battery from ? having trouble locating one .
Thanks in advance nick
Nick Harrisson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 39
Todo El Tiempo: 7,099
