Saltar al contenido principal
Chromebook 14-x015wm Key Replacement
Qué necesitas
  1. Chromebook 14-x015wm Key Replacement, Key: paso 1, imagen 1 de 1
    • Take a flathead screw driver and place it right under the key. Very gently pry it up. If it doesn't come off right away, try and loosen it by using the flathead on all four sides and wiggle it.
  2. Chromebook 14-x015wm Key Replacement: paso 2, imagen 1 de 1
    • Once the key is off, all you have to do to put a new key on is center it exactly how the original one was, and push down.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 222
