Saltar al contenido principal
Chevy 305 Engine Main Bearings Replacement
Qué necesitas
  1. Chevy 305 Engine Main Bearings Replacement, Main Bearings: paso 1, imagen 1 de 2 Chevy 305 Engine Main Bearings Replacement, Main Bearings: paso 1, imagen 2 de 2
    • Remove the 18 bolts holding the oil pan in place (fourteen ⅜” bolts & four ½” bolts on each corner) and remove oil pan using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
    • Do not remove the oil pan gasket yet.
  2. Chevy 305 Engine Main Bearings Replacement: paso 2, imagen 1 de 1
    • Remove the 5 main bearing caps.
    • Three caps with four ⅝ bolts and two caps with two ⅝ bolts at the front and rear of crankshaft.
    • Gently tap the side of the cap with a rubber mallet if needed to break free.
    • DO NOT SWAP THE LOCATIONS OR DIRECTIONS OF THE CAPS.
  3. Chevy 305 Engine Main Bearings Replacement: paso 3, imagen 1 de 1
    • Remove and replace main bearings.
    • Liberally apply assembly lubricant/oil to the new bearing surfaces and crankshaft journal.
    • Gently tap the cap against the engine block or use a thin flathead to remove.
  4. Chevy 305 Engine Main Bearings Replacement: paso 4, imagen 1 de 1
    • Put the main bearing caps back.
    • Three caps with four ⅝ bolts and two caps with two ⅝ bolts at the front and rear of crankshaft and torque to specs. (65 ft.-lbs.)
    • Do not swap the locations or directions of the caps during reinstallation. (reverse of removal)
  5. Chevy 305 Engine Main Bearings Replacement: paso 5, imagen 1 de 2 Chevy 305 Engine Main Bearings Replacement: paso 5, imagen 2 de 2
    • Replace the oil pan gasket.
    • Use a razor blade, flathead screwdriver or putty knife to clean up the old gasket and wipe down where the old gasket was with brake cleaner and paper towels before placing a new gasket.
    • Be careful not to drop any gasket debris into the engine.
  6. Chevy 305 Engine Main Bearings Replacement: paso 6, imagen 1 de 1
    • Put the oil pan back into place.
    • Fourteen ⅜” bolts & four ½” bolts on each corner) and torque bolts to specs. (12 ft.-lbs.) (reverse of removal)
Linea de Meta
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 54
Todo El Tiempo: 2,915
