Introducción
If your ChefsChoice M677 electric kettle is struggling to turn on, you may have to replace the power cord. Use this guide to replace your power cord. Before using this guide make sure that the current cord still won't work so that you know you're fixing the right issue.
A functional power cord provides energy to your ChefsChoice Kettle and when damaged, you'll need to replace it. No need to worry as replacement is cheap and easy. Continue by following the steps to replace your power cord.
Qué necesitas
Three 3/8" standard Phillips screws
And one 3/8" non-standard triangular Phillips screw.
Use your hands to pull the black cylinder out from the center of the baseplate. This is the power coupling.
The GREEN wire is the 'ground' or 'protection' wire. It is connected to the center post.
The other two wires are both BLACK. You can distinguish them by feel:
The smooth wire is the 'neutral' wire.
The ribbed wire is the 'hot' wire.
On the replacement cord, remove the white, green, and black protective caps. By hand, affix one connector to each cord wire. Follows these steps for each wire:
Twist the copper strands on the wire so you can cleanly insert the wire into the connector.
Push the copper wiring into the connector until the insulation prevents further insertion.
Using the multi-tool in crimper mode (or a special crimping tool), apply pressure on the connector 'shank' where the wire was inserted.
The ridge that you achieve by crimping should look the same as the connector shown here on the green wire. Give the connector a gentle pull to confirm it is well connected to the wire (it should not slip off).
Repeat steps 10 and 11 for the remaining two wires requiring connectors.
Reinsert the power coupling (the black cylinder) through the baseplate.
Slide the connectors into the exposed metal prongs protruding from the power coupling. This may require a little force because the connection is a tight fit.
Reattach the black plastic oval piece in order to secure and stabilize the cord wires.
Align the holes on the two halves of the baseplate precisely.
Using a #1 Phillips head screwdriver, tighten the three 3/8" Philips head screws in the holes located along the outer edge of the base plate.
Using a #1 TRIANGULAR head screwdriver, tighten the 3/8" TRIANGULAR Phillips screw at the center of the base plate.
2 personas más completaron esta guía.
