Saltar al contenido principal
Chefmate TO-09 Timer Replacement
Qué necesitas
  1. Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: paso 1, imagen 1 de 3 Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: paso 1, imagen 2 de 3 Chefmate TO-09 Timer Replacement, Chefmate TO-09 Timer Replacement: paso 1, imagen 3 de 3
    • Examine the condition of the appliance.
    • Remove the tray from inside the toaster oven before dissembling.
    • With the tray removed, this is a great opportunity to clean your toaster oven . Built up debris left over time could lead to functional issues in the future!
  2. Chefmate TO-09 Timer Replacement: paso 2, imagen 1 de 3 Chefmate TO-09 Timer Replacement: paso 2, imagen 2 de 3 Chefmate TO-09 Timer Replacement: paso 2, imagen 3 de 3
    • Flip the toaster oven on its head so that its bottom side is facing upwards.
    • Use a Phillips #0 screwdriver to remove the four screws hidden underneath the legs of the appliance.
    • There are two legs covering the two screws in the front peg .
    • The other two screws are visible under the back legs.
  3. Chefmate TO-09 Timer Replacement: paso 3, imagen 1 de 3 Chefmate TO-09 Timer Replacement: paso 3, imagen 2 de 3 Chefmate TO-09 Timer Replacement: paso 3, imagen 3 de 3
    • Return the toaster oven to its upright position and rotate it so its backside is facing you.
    • Use the Phillips #0 screwdriver to unscrew the four screws visible on the backside.
    • Keep track of loose screws for later re-assembly.
  4. Chefmate TO-09 Timer Replacement: paso 4, imagen 1 de 3 Chefmate TO-09 Timer Replacement: paso 4, imagen 2 de 3 Chefmate TO-09 Timer Replacement: paso 4, imagen 3 de 3
    • With the appliance facing you, remove the top cover of the toaster oven to access the timer location.
  5. Chefmate TO-09 Timer Replacement: paso 5, imagen 1 de 3 Chefmate TO-09 Timer Replacement: paso 5, imagen 2 de 3 Chefmate TO-09 Timer Replacement: paso 5, imagen 3 de 3
    • Use the flat screwdriver as a wedge and pop the timer knob out of place.
    • If you have difficulty removing the timer by hand, use a flat plier to pry off the timer knob.
  6. Chefmate TO-09 Timer Replacement: paso 6, imagen 1 de 3 Chefmate TO-09 Timer Replacement: paso 6, imagen 2 de 3 Chefmate TO-09 Timer Replacement: paso 6, imagen 3 de 3
    • With the timer in hand, gently remove the two wires attached to the square object.
    • Unplug the timer wire gently, or else this may cause damage to the cables.
  7. Chefmate TO-09 Timer Replacement: paso 7, imagen 1 de 3 Chefmate TO-09 Timer Replacement: paso 7, imagen 2 de 3 Chefmate TO-09 Timer Replacement: paso 7, imagen 3 de 3
    • Before replacing your timer with a new one, you may try to lubricate it first to see if it fixes the issue.
    • Apply WD-40 to the timer's slight peek edge.
    • Let the WD-40 sit and take effect for around 30 seconds or a minute after you spray it onto the timer.
    • The WD-40's oil will seep inside the timer, reaching the tiny gear of the timer.
    • WD-40 is flammable. Be sure to read the instruction label before using WD-40 Two-Way Spray Can.
    • Not cleaning/wiping off excess WD-40 oil on the timer will start a fire in the toaster oven.
    • You can test the timer using a flat head screwdriver to turn the timer to see if it ticks/works.
Conclusión
Una persona más ha completado esta guía.
Andy Tran
Miembro Desde 04/05/22
172 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 361
