Saltar al contenido principal
Chefman RJ-38-V2-35 Fryer Basket Replacement
Qué necesitas
  1. Chefman RJ-38-V2-35 Fryer Basket Replacement, Fryer Basket: paso 1, imagen 1 de 1
    • Make sure the air fryer is unplugged and the basket is cool enough to handle.
    • Remove the basket from the air fryer.
  2. Chefman RJ-38-V2-35 Fryer Basket Replacement: paso 2, imagen 1 de 1
    • Place the fryer basket on a flat surface.
    • Using the Phillips #1 screwdriver, remove four 5mm screws on the inside of the fryer basket (left two screws shown).
  3. Chefman RJ-38-V2-35 Fryer Basket Replacement: paso 3, imagen 1 de 1
    • Separate the handle from the basket.
Conclusión
Una persona más ha completado esta guía.
Benn Rutledge
Miembro Desde 10/17/18
127 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team S1-G4, Rose Fall 2018 Miembro de UW Tacoma, Team S1-G4, Rose Fall 2018
UWT-ROSE-F18S1G4
4 Miembros
3 Guías creadas
4 comentarios
I need the plate inside the basket. The coating is coming off, Is it safe to use?
Eileen Morrison - Contestar
Where can I buy only the basket or just the plate? I need replacement but don’t seem to find the parts…
Eszter Stranszky - Contestar
I need the plate inside the basket. Coating is coming off.
Sandy Mentzer - Contestar
Where can I buy replacement rubber feet for the fryer basket plate? Mine came off and went down the disposal!! Are they required for proper heating and frying??
Betty Johnson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 13
Ultimos 30 días: 52
Todo El Tiempo: 3,507
