Saltar al contenido principal
Chef's Choice M115 Power Switch Replacement
Qué necesitas
  1. Chef's Choice M115 Power Switch Replacement, Case: paso 1, imagen 1 de 2 Chef's Choice M115 Power Switch Replacement, Case: paso 1, imagen 2 de 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Power Switch Replacement: paso 2, imagen 1 de 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Power Switch Replacement: paso 3, imagen 1 de 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Power Switch Replacement: paso 4, imagen 1 de 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Power Switch Replacement, Power Switch: paso 5, imagen 1 de 1
    • Carefully lift the entire motor assembly out of the case.
  6. Chef's Choice M115 Power Switch Replacement: paso 6, imagen 1 de 2 Chef's Choice M115 Power Switch Replacement: paso 6, imagen 2 de 2
    • Using a screw driver, unclip the edges of the switch by pushing them inwards and nudging the switch out of the plastic casing. You will hear a click when the edges unhook from the casing.
  7. Chef's Choice M115 Power Switch Replacement: paso 7, imagen 1 de 2 Chef's Choice M115 Power Switch Replacement: paso 7, imagen 2 de 2
    • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
    • This may require a fair bit of force. Use caution to not damage the device, yourself, or your surroundings.
Conclusión
2 personas más completaron esta guía.
Equipo
IUPUI, Team 3-3, Harley Fall 2015 Miembro de IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 321
