Saltar al contenido principal
Chef's Choice M115 Linkage Pins Replacement
Qué necesitas
  1. Chef's Choice M115 Linkage Pins Replacement, Case: paso 1, imagen 1 de 2 Chef's Choice M115 Linkage Pins Replacement, Case: paso 1, imagen 2 de 2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Linkage Pins Replacement: paso 2, imagen 1 de 1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Linkage Pins Replacement: paso 3, imagen 1 de 1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Linkage Pins Replacement: paso 4, imagen 1 de 1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Linkage Pins Replacement, Grinding Disc Linkage Pins: paso 5, imagen 1 de 1
    • Remove the motor and shaft assembly from the bottom of the case housing.
  6. Chef's Choice M115 Linkage Pins Replacement: paso 6, imagen 1 de 2 Chef's Choice M115 Linkage Pins Replacement: paso 6, imagen 2 de 2
    • Use a screwdriver to push the pin out of the rod.
    • Use pliers to pull the pin the rest of the way out.
Conclusión
Una persona más ha completado esta guía.
James Herin
Miembro Desde 10/27/15
128 Reputación
1 Guía escrita
Equipo
IUPUI, Team 3-3, Harley Fall 2015 Miembro de IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
5 Miembros
12 Guías creadas
Un comentario
Where would you obtain new linkage pins. Can I use a similar gauged wire? What, and where can I find a suitable replacement?
Josh Brown - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 20
Todo El Tiempo: 1,783
