Saltar al contenido principal
Introducción
Learn to check the power steering fluid level on your Mercedes W123 to keep that boat turning smoothly!
Herramientas
No se especificaron herramientas.
Partes
  1. Your power steering fluid reservoir is located within the pump which is on the right side of your engine, when facing it from the front of the car. In the U.S. this is the driver's side. Attached to it are the following components:
    • Your power steering fluid reservoir is located within the pump which is on the right side of your engine, when facing it from the front of the car. In the U.S. this is the driver's side. Attached to it are the following components:
    • Pulley and belt
    • Hoses that connect to the steering box
    • Cover
    • To check the level of power steering fluid inside the pump's reservoir the cover will need to be removed.
  2. To remove the cover begin by loosening the retaining nut. On this car it is a metal wing nut, but on some W123's there is a plastic thumb nut.
    • To remove the cover begin by loosening the retaining nut. On this car it is a metal wing nut, but on some W123's there is a plastic thumb nut.
  3. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  4. As the nut loosens use a second hand to hold the cover down. There is a spring under the cover that will force it up and make it harder to remove the retaining nut.
    • As the nut loosens use a second hand to hold the cover down. There is a spring under the cover that will force it up and make it harder to remove the retaining nut.
  5. With the nut removed slowly and carefully allow the spring to push up on the cover until the tension is removed.
    • With the nut removed slowly and carefully allow the spring to push up on the cover until the tension is removed.
    • Remove the cover and set aside someplace clean.
  6. With the cover removed you can now observe the fluid level.
    • With the cover removed you can now observe the fluid level.
    • The level should reach the small ledge at the back left of the reservoir.
    • While the cover is off you can also check the condition of the fluid by piping a small amount in to a syringe or turkey baster (used only for automotive fluids - never use it in the kitchen again!) If the fluid looks dark, instead of a clean red, consider changing it and the filter.
Conclusión
13 personas más completaron esta guía.
Nicolas Siemsen
Miembro Desde 06/12/13
31,502 Reputación
79 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
287 Miembros
815 Guías creadas
This perfectly put together guide, made this process absolutely effortless ! Thank you
Sandra - Contestar
The indicator marker inside the pump reservoir is to measure fluid at hot (operating ) temperatures only. When cold or ambient the level should be between 6 and 8mm below that marker. The spring in this pump is missing the detent that holds it down. The spring is not meant to be held down by the reservoir cap.
Stephen Duclos - Contestar
Thanks a lot for sharing your knowledge and may God bless you. Take care.
Abdoolah Khodabocus - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 8
Últimos 7 Días: 40
Últimos 30 Días: 131
Todo El Tiempo: 9,869
