Saltar al contenido principal
Check for OBD2 codes, ABS, DTC without a scanner
Qué necesitas
    • Turn ignition two clicks to the ON position
    • Insert a bent paperclip into the SCC connector. (See video for where the SCC connector is located)
    • Touch both of the exposed pins to short the connection. Continue to short the connection for more than 5 seconds.
    • Any codes will display on the Odometer/Trip display, or "NO" if there are no stored codes
    • Remove paperclip and wait 10 seconds
    • Turn ignition OFF and remove key
Linea de Meta
ndsol
Miembro Desde 11/11/10
3,042 Reputación
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 36
Ultimos 30 días: 121
Todo El Tiempo: 4,407
