Introducción
The purpose of this guide is to help grill owners patch rusty and corroded drip pans on Charbroil grills with permanently riveted drip pans. Rather than discarding the grill and spending hundreds of dollars for a new one, this procedure will allow the grill owner to extend the usable life of his or her grill.
Qué necesitas
Make an initial assessment of the extent of the corrosion to the drip pan.
Use a wire brush to remove the most corroded metal.
Use the tin snips to remove the least corroded metal.
Drill four pilot holes through the grease outlet from the top side of the grill using either a cordless or power drill. These holes will be used later to provide space to use the tin snips.
Cut the remaining metal between the pilot holes with the tin snips to form a single grease outlet.
Upon completion, this repair will extend the usable life of your grill and reduce waste deposited into landfills.
3 personas más completaron esta guía.
2 comentarios
Thank you so much for posting this. Question: what type of sheet metal? Aluminum or Steel?
What kind of material? Aluminum?
