Introducción
According to this guide can easily replace the home security door cylinder.
Qué necesitas
It is advisable to work with two people, one holding the outer handle on the outside and the other unloading the screw on the other side.
Remove the two screws.
Use pry bar carefully pry around, you can remove both sides of the door handle.
Remove the lock cylinder lock screw.
Push the lock cylinder to one side of the door, which side is easy to push.
Please re-install in the reverse order of this guide.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ irlanda nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
