Saltar al contenido principal
Chain Adjustment
  1. Chain Adjustment, Chain Adjustment: paso 1, imagen 1 de 3 Chain Adjustment, Chain Adjustment: paso 1, imagen 2 de 3 Chain Adjustment, Chain Adjustment: paso 1, imagen 3 de 3
    • Locate the two nuts and screws to adjust the chain saw.
    • YOU MAY NEED TO PULL THE BLACK INTER CASING THAT THE CHAIN GO AROUND TO TIGHT
  2. Chain Adjustment: paso 2, imagen 1 de 3 Chain Adjustment: paso 2, imagen 2 de 3 Chain Adjustment: paso 2, imagen 3 de 3
    • USE nut driver 7/16 to loosen the nuts and realignment chain around the black casing.
    • Tight the chain saw chain that it tight enough that it move around the black inter case.
    • YOU must have to readjust move than once.
    • Must have to pull the black casing forward . Readjust the nuts agaian.
Conclusión
kempc8
Miembro Desde 11/22/13
899 Reputación
7 Guías creadas
Equipo
K and K Fixit Miembro de K and K Fixit
Business
1 Miembro
11 Guías creadas
Un comentario
Hi kempc8,
Recently i came up with a post Ultimate Pole saw guide 2017.
I have also listed Top brands with respect to Pole saw.
I probably missed out your brand
Kindly give a look here link to bestpolesaw.com
Please suggest me whether i can add your brand or any of the products associated with our niche .
Thanks
rmanojkumar.007 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 2,149
