Introducción
If the dial is stuck in any particular position it will be necessary to replace. This guide will show how to locate and replace the dial.
Qué necesitas
Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
Remove the back panel of the device by lifting upward.
Remove the battery from the meter before continuing.
Remove the four 7mm Phillips screws holding the circuit board in place.
Carefully remove dial from device by lifting upward.
Clean existing dial or replace if necessary.
Una persona más ha completado esta guía.
