Saltar al contenido principal
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
Qué necesitas
  1. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Position Device: paso 1, imagen 1 de 1
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: paso 2, imagen 1 de 2 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: paso 2, imagen 2 de 2
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel: paso 3, imagen 1 de 1
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: paso 4, imagen 1 de 2 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: paso 4, imagen 2 de 2
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Motherboard: paso 5, imagen 1 de 1
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
Conclusión
6 personas más completaron esta guía.
Anna Kihm
Miembro Desde 10/13/14
956 Reputación
5 Guías creadas
Equipo
Clemson, Team 2-4, Benson Fall 2014 Miembro de Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
Miembros de 4
6 Guías creadas
1Guía Comentario
What is the little dial on the circuit board on the upper right that has numbers 1 through 3 on it and it can be adjusted thank you
Thomas Clawson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 2,854
