Introducción
If the dial cannot spin then it is likely that the ball bearings are missing or not properly lubricated.
Qué necesitas
Place the meter face down, and the back panel and screws can be seen.
Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
Remove the back panel of the device by lifting upward.
Remove the battery from the meter before continuing.
Remove the four 7mm Phillips screws holding the circuit board in place.
Carefully remove dial from device by lifting upward.
Clean existing dial or replace if necessary.
Locate ball bearings. Carefully remove.
If both ball bearings are still present, try lubricating ball bearings with multi-use lubricant.
If one or both ball bearings are missing, simply replace.
3 personas más completaron esta guía.
