Saltar al contenido principal
Celestron Nature DX Focus Knob Replacement
Qué necesitas
  1. Celestron Nature DX Focus Knob Replacement, Skin Cover: paso 1, imagen 1 de 2 Celestron Nature DX Focus Knob Replacement, Skin Cover: paso 1, imagen 2 de 2
    • Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
  2. Celestron Nature DX Focus Knob Replacement: paso 2, imagen 1 de 2 Celestron Nature DX Focus Knob Replacement: paso 2, imagen 2 de 2
    • Start peeling the skin away from the center. Apply force as there is an adhesive substance that is binding the skin to the device. Continue peeling until skin cover slides off completely.
  3. Celestron Nature DX Focus Knob Replacement: paso 3, imagen 1 de 1
    • Repeat steps 1 and 2 for the other side.
  4. Celestron Nature DX Focus Knob Replacement, Focus Knob: paso 4, imagen 1 de 1
    • Remove the top cover of the focus knob as shown. Simply twisting and pulling the cover will slide it off.
  5. Celestron Nature DX Focus Knob Replacement: paso 5, imagen 1 de 1
    • Use a magnetic pickup tool or magnetic screwdriver head to remove the guard. The guard should come right off without much resistance.
  6. Celestron Nature DX Focus Knob Replacement: paso 6, imagen 1 de 1
    • Unscrew the focus knob. It should come off without much resistance or pressure.
    • Parts revealed will be heavily lubricated. Consider wearing gloves.
Conclusión
Bryce Colangelo
Miembro Desde 02/15/17
525 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S6-G6, Lacy Spring 2017 Miembro de USF Tampa, Team S6-G6, Lacy Spring 2017
USFT-LACY-S17S6G6
4 Miembros
10 Guías creadas
Un comentario
Hello.
I have the same model with a little bit to hard working focus knob.
Is it possible to adjust it in order to make it working smoothly?
Tkanks.
Zenon Zuza - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 818
