Saltar al contenido principal
Ceiva LF2003 Internal Plastic Screen Frame Replacement
Qué necesitas
  1. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Exterior Frame and Matting: paso 1, imagen 1 de 1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Internal Plastic Screen Frame Replacement: paso 2, imagen 1 de 1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Internal Plastic Screen Frame Replacement: paso 3, imagen 1 de 1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Internal Plastic Screen Frame Replacement: paso 4, imagen 1 de 1
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Internal Plastic Screen Frame: paso 5, imagen 1 de 1
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Internal Plastic Screen Frame Replacement: paso 6, imagen 1 de 2 Ceiva LF2003 Internal Plastic Screen Frame Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
Conclusión
Una persona más ha completado esta guía.
Casey Glasgow
Miembro Desde 01/26/14
510 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 9-25, Maness Winter 2014 Miembro de Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 100
