Saltar al contenido principal
Ceiling Fan Pull Chain Switch Replacement
Qué necesitas
  1. Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: paso 1, imagen 1 de 2 Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: paso 1, imagen 2 de 2
    • Caution: Turn off the power from the circuit breaker and turn off any light switches that provide power to the ceiling fan.
    • Remove the white cover by unscrewing the nut on the bottom from where the chain is hanging.
  2. Ceiling Fan Pull Chain Switch Replacement: paso 2, imagen 1 de 3 Ceiling Fan Pull Chain Switch Replacement: paso 2, imagen 2 de 3 Ceiling Fan Pull Chain Switch Replacement: paso 2, imagen 3 de 3
    • Caution: Let the bulbs cool off before you remove them.
    • Remove the bulbs from their sockets.
  3. Ceiling Fan Pull Chain Switch Replacement: paso 3, imagen 1 de 2 Ceiling Fan Pull Chain Switch Replacement: paso 3, imagen 2 de 2
    • Remove the screws around the base.
    • Remove the fan housing.
  4. Ceiling Fan Pull Chain Switch Replacement: paso 4, imagen 1 de 1
    • Pull the switch out of the fan housing, leaving the wires attached.
  5. Ceiling Fan Pull Chain Switch Replacement: paso 5, imagen 1 de 3 Ceiling Fan Pull Chain Switch Replacement: paso 5, imagen 2 de 3 Ceiling Fan Pull Chain Switch Replacement: paso 5, imagen 3 de 3
    • Cut the colored wires from the switch using a pair of wire cutters.
    • On some switch models, the wires can be detached by pulling.
  6. Ceiling Fan Pull Chain Switch Replacement: paso 6, imagen 1 de 3 Ceiling Fan Pull Chain Switch Replacement: paso 6, imagen 2 de 3 Ceiling Fan Pull Chain Switch Replacement: paso 6, imagen 3 de 3
    • Note the wire colors and the terminal they attach to on the old switch.
    • 1 - Red
    • 2 - Purple
    • 3 - Yellow
    • L - Black
  7. Ceiling Fan Pull Chain Switch Replacement: paso 7, imagen 1 de 1
    • Attach the colored wires to the new switch's respective terminals.
  8. Ceiling Fan Pull Chain Switch Replacement: paso 8, imagen 1 de 2 Ceiling Fan Pull Chain Switch Replacement: paso 8, imagen 2 de 2
    • Put back the switch in the hole in the fan housing from the inside.
    • Tighten up the screws on the outside.
  9. Ceiling Fan Pull Chain Switch Replacement: paso 9, imagen 1 de 3 Ceiling Fan Pull Chain Switch Replacement: paso 9, imagen 2 de 3 Ceiling Fan Pull Chain Switch Replacement: paso 9, imagen 3 de 3
    • Put back the white cover and then tighten up the nut at the bottom of the cover from where the chain is hanging.
  10. Ceiling Fan Pull Chain Switch Replacement: paso 10, imagen 1 de 2 Ceiling Fan Pull Chain Switch Replacement: paso 10, imagen 2 de 2
    • Turn the power back on and test the switch to find if it is working or not.
Linea de Meta
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 73
Ultimos 30 días: 363
Todo El Tiempo: 11,200
