Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Cassida Counterfeit Detector Motor Band Replacement
Qué necesitas
  1. Cassida Counterfeit Detector Motor Band Replacement, Cassida Counterfeit Detector: paso 1, imagen 1 de 1
    • Remove the rubber legs.
  2. Cassida Counterfeit Detector Motor Band Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #1 bit, remove the circled screws.
  3. Cassida Counterfeit Detector Motor Band Replacement: paso 3, imagen 1 de 1
    • Pry the top cover off, starting from the side with the switch, with a metal spudger.
  4. Cassida Counterfeit Detector Motor Band Replacement: paso 4, imagen 1 de 1
    • Pop the 4 tabs on the top of the machine up with a metal spudger and then remove the 2 side panels.
  5. Cassida Counterfeit Detector Motor Band Replacement: paso 5, imagen 1 de 1
    • Disconnect the wires circled and then remove the top section from the bottom section just by pulling the top section straight up and holding onto the bottom.
  6. Cassida Counterfeit Detector Motor Band Replacement: paso 6, imagen 1 de 1
    • All the parts disassembled.
  7. Cassida Counterfeit Detector Motor Band Replacement, Motor Band: paso 7, imagen 1 de 1
    • This is the band you will be replacing. If it is broken or loose, remove from the device completely.
  8. Cassida Counterfeit Detector Motor Band Replacement: paso 8, imagen 1 de 1
    • Install new band by placing it around the small grey pulley and then working it around the larger black pulley.
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 248
