Introducción
This guide will walk you through step-by-step instructions on how to change a broken or damaged screen of your Casio fx-9750GII graphing calculator.
A display screen shows the output of what is being input into the device through the keys. A damaged screen would display distorted prints from the calculator.
Before beginning this repair, make sure to take out the DC batteries at the back of the graphing calculator. Take extra precaution if screen appears to be shattered or broken. Put on rubber gloves to protect your hands if needed.
Qué necesitas
Turn off the calculator and flip it over so the backside is facing up.
Slide the battery door off and remove all of the batteries.
2 comentarios
thanks for the short description and pics. my screen cable appears to be soldered directly. I would help if you said more than "separate the screen cable from the motherboard" Perhaps add another pic or two of just that description? Are you breaking the wires? are you soldering on the new replacement board? are you taking off just the screen from that main 'calculator' electronics board?
Where to get the new replacement screen?
