Partes
  1. This is the calculator in question.
    • This is the calculator in question.
      • Features a black and white dot matrix screen.
  2. Turn the calculator over. Locate the six screws on the rear of the device.
    • Turn the calculator over.
    • Locate the six screws on the rear of the device.
      • These are Philips #00 screws.
    • Keep the screws you remove in a safe place so they don't get lost.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  4. Once the screws are removed, carefully lift the back panel off, lifting the top end first. Place the panel to one side.
    • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
    • Place the panel to one side.
    • You can now see the battery.
  5. Remove the battery
    • Remove the battery
    • Lift it up from the right hand side to avoid damaging the spring.
    • You may find this easier to do by prying it out with the screwdriver.
  6. Now you can insert the new battery Ensure you place it in spring-first.
    • Now you can insert the new battery
      • Ensure you place it in spring-first.
    • Congratulations! You have replaced the battery.
    • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
    • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
Conclusión
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
23 personas más completaron esta guía.
Sam
Miembro Desde 23/09/12
869 Reputación
1 Guía escrita
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - Contestar
what battery size is it? R03?
Humerdom - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 11
Últimos 7 Días: 121
Últimos 30 Días: 554
Todo El Tiempo: 34,093
