Saltar al contenido principal
Casio WK-220 White Keys Replacement
Qué necesitas
  1. Casio WK-220 White Keys Replacement, White Keys: paso 1, imagen 1 de 2 Casio WK-220 White Keys Replacement, White Keys: paso 1, imagen 2 de 2
    • Place device face-down
    • Remove 23 16mm screws with Phillips #2 screwdriver
  2. Casio WK-220 White Keys Replacement: paso 2, imagen 1 de 2 Casio WK-220 White Keys Replacement: paso 2, imagen 2 de 2
    • Pry up long back panels with plastic opening tool
    • Remove panels
  3. Casio WK-220 White Keys Replacement: paso 3, imagen 1 de 1
    • Turn device around so keys are face-up
  4. Casio WK-220 White Keys Replacement: paso 4, imagen 1 de 2 Casio WK-220 White Keys Replacement: paso 4, imagen 2 de 2
    • Pull back panel away from keyboard and out of the way
  5. Casio WK-220 White Keys Replacement: paso 5, imagen 1 de 3 Casio WK-220 White Keys Replacement: paso 5, imagen 2 de 3 Casio WK-220 White Keys Replacement: paso 5, imagen 3 de 3
    • Remove speaker(s) if necessary to access desired key section(s)
    • Use Phillips #2 screwdriver to remove two 16 mm screws (circled in red)
    • Pop wires out of plastic holders so speaker can be moved out of the way
    • Move speaker out of the way
    • See speaker replacement guide for more detail on these steps
  6. Casio WK-220 White Keys Replacement: paso 6, imagen 1 de 3 Casio WK-220 White Keys Replacement: paso 6, imagen 2 de 3 Casio WK-220 White Keys Replacement: paso 6, imagen 3 de 3
    • Remove 4 18 mm screws (circled in red) from desired key section using Philips #1 screwdriver
    • Gently push white keys away from screws and pull up to remove from keyboard. Repeat this with the black keys
    • Reassemble with new/cleaned keys
Conclusión
Alexa
Miembro Desde 01/24/17
687 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 10-2, Banghart Winter 2017 Miembro de Cal Poly, Team 10-2, Banghart Winter 2017
CPSU-BANGHART-W17S10G2
Miembros de 4
6 Guías creadas
Un comentario
Hi. Will this work for broken keys please?
Deborah - EDEN Henderson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 1,612
