Saltar al contenido principal
Casio MarineGear wristwatch battery Replacement
Qué necesitas
  1. Casio MarineGear wristwatch battery Replacement, Opening the back: paso 1, imagen 1 de 2 Casio MarineGear wristwatch battery Replacement, Opening the back: paso 1, imagen 2 de 2
    • Use a Phillips #00 to remove the 4 screws holding the back.
  2. Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: paso 2, imagen 1 de 3 Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: paso 2, imagen 2 de 3 Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to remove the plastic ring that aligns the movement.
    • In this case the watch didn't have a battery installed, but to get the battery out you have to use the tweezers and unhook the latch holding the battery in place.
    • The correct battery for this watch is CR2025 3V button cell.
  3. Casio MarineGear wristwatch battery Replacement, Install new battery: paso 3, imagen 1 de 2 Casio MarineGear wristwatch battery Replacement, Install new battery: paso 3, imagen 2 de 2
    • Insert the new battery into it's place.
    • Latch the battery hook back into it's place, securing the battery.
    • Turn the movement over to verify the watch is now working.
    • You may have to touch the AC (negative) side of battery, to the metal grounding plate. (It's stated on the white label and marks are very clear).
  4. Casio MarineGear wristwatch battery Replacement, Reassemble the watch: paso 4, imagen 1 de 3 Casio MarineGear wristwatch battery Replacement, Reassemble the watch: paso 4, imagen 2 de 3 Casio MarineGear wristwatch battery Replacement, Reassemble the watch: paso 4, imagen 3 de 3
    • Make sure the rubber gasket is placed correctly in it's groove, as it is there for water resistance.
    • Place the back cover on and fasten the 4 Phillips #00 screws securing the back plate.
    • Set the time and date, and your watch is now in working order again.
Conclusión
Reassembly is detailed in the guide
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,516 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 55
Todo El Tiempo: 1,132
