Saltar al contenido principal
Casio LK-170 Speaker Replacement
Qué necesitas
  1. Casio LK-170 Speaker Replacement, Speaker: paso 1, imagen 1 de 3 Casio LK-170 Speaker Replacement, Speaker: paso 1, imagen 2 de 3 Casio LK-170 Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Locate the seven 11mm screws on the back of the keyboard in order to remove the speaker from the front of the keyboard.
    • There are 7 screws that need to be removed in total to replace one speaker. Use a JIS-1 screwdriver to remove these screws: 2 on the back panel, and 4 on the side of the keyboard.
    • Three of these seven screws are slightly hidden and may be hard to find.
  2. Casio LK-170 Speaker Replacement: paso 2, imagen 1 de 2 Casio LK-170 Speaker Replacement: paso 2, imagen 2 de 2
    • Gently remove the speaker and its compartment from the front of the keyboard.
  3. Casio LK-170 Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the four 11 mm screws with JIS-1 screwdriver on the four corners of the silver square on the back of the speaker.
  4. Casio LK-170 Speaker Replacement: paso 4, imagen 1 de 2 Casio LK-170 Speaker Replacement: paso 4, imagen 2 de 2
    • A soldering iron is needed to remove the wires connected to the speaker in order to fully replace it. For soldering help, take a look at the Soldering and Desoldering Connections guide.
    • Desolder the metal that attaches the blue and white wires to the speaker.
    • Remove the speaker.
Conclusión
Samantha Baker
Miembro Desde 01/24/17
425 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-2, Banghart Winter 2017 Miembro de Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Miembros
5 Guías creadas
Un comentario
How much is a replacement speaker and where do I get one for the BRAND new keyboard U just bought that doesnt work through the left speaker (LK 265)
Heather Quigley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 677
