Saltar al contenido principal
Casio LK-170 Key Replacement
Qué necesitas
  1. Casio LK-170 Key Replacement, Key: paso 1, imagen 1 de 3 Casio LK-170 Key Replacement, Key: paso 1, imagen 2 de 3 Casio LK-170 Key Replacement, Key: paso 1, imagen 3 de 3
    • You will be removing 17 11mm screws with a JIS-1 screwdriver to detach the back of the keyboard from the front.
    • You will begin by removing 4 screws on each side of the piano, circled in red.
    • You will then remove the four screws that are a little hidden, circled in orange.
    • Next, remove the two screws in the middle of piano, as well as the three screws on the top of the piano, circled in yellow.
  2. Casio LK-170 Key Replacement: paso 2, imagen 1 de 2 Casio LK-170 Key Replacement: paso 2, imagen 2 de 2
    • After flipping the keyboard over to the front, carefully remove the the front panel from the back panel of the keyboard using your hands.
    • You should now see the screws holding the keys in place.
    • There are five 18mm screws per section of keys.
    • With a JIS-1 bit, unscrew the five screws in the section with the key you want to replace.
  3. Casio LK-170 Key Replacement: paso 3, imagen 1 de 2 Casio LK-170 Key Replacement: paso 3, imagen 2 de 2
    • You will be able to pick up the white keys with your hands and remove them.
Conclusión
Una persona más ha completado esta guía.
Samantha Baker
Miembro Desde 01/24/17
425 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-2, Banghart Winter 2017 Miembro de Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
Miembros de 3
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 2,503
