Saltar al contenido principal
Casio LK-170 Button Replacement
Qué necesitas
  1. Casio LK-170 Button Replacement, Button: paso 1, imagen 1 de 2 Casio LK-170 Button Replacement, Button: paso 1, imagen 2 de 2
    • Using a JIS-1 screwdriver, remove the seven 11 mm screws located on the back of the keyboard.
  2. Casio LK-170 Button Replacement: paso 2, imagen 1 de 1
    • Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
    • Flip the middle panel up so that the component board can be seen.
  3. Casio LK-170 Button Replacement: paso 3, imagen 1 de 3 Casio LK-170 Button Replacement: paso 3, imagen 2 de 3 Casio LK-170 Button Replacement: paso 3, imagen 3 de 3
    • In this step, you will be removing a total of 26 screws.
    • First, you will use a PH-1 bit to remove the 17 8mm screws circled in red.
    • Next, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wires, circled in orange.
    • Then, using a JIS-1 bit, we will remove three 7mm screws from the circuit board, circled in yellow.
    • After removing the circuit board, the last three screws are revealed, circled in green. You will use the PH-1 bit to remove these last screws.
  4. Casio LK-170 Button Replacement: paso 4, imagen 1 de 1
    • Once all the screws have been removed, lift the panel and place it face down on the keys.
    • The panel is connected to the keyboard, so do not try to remove it.
  5. Casio LK-170 Button Replacement: paso 5, imagen 1 de 2 Casio LK-170 Button Replacement: paso 5, imagen 2 de 2
    • Under the panel are the buttons. Remove them by pulling from any corner with your fingers.
    • Remove all the buttons that need to be replaced.
Conclusión
Eileen Tran
Miembro Desde 01/24/17
105 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 13-2, Banghart Winter 2017 Miembro de Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 572
