Saltar al contenido principal
Casio G-Shock GA110-1B Battery Replacement
Qué necesitas
Resumen del Video
  1. Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: paso 1, imagen 1 de 3 Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: paso 1, imagen 2 de 3 Casio G-Shock GA110-1B Battery Replacement, A Guide on Battery Replacement: paso 1, imagen 3 de 3
    • Remove the four screws from the back of the watch using the Phillips #0 Screwdriver
  2. Casio G-Shock GA110-1B Battery Replacement: paso 2, imagen 1 de 3 Casio G-Shock GA110-1B Battery Replacement: paso 2, imagen 2 de 3 Casio G-Shock GA110-1B Battery Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to remove the metal cover.
    • Make sure not to lose the rubber circle underneath the metal cover because it's part of the watch.
  3. Casio G-Shock GA110-1B Battery Replacement: paso 3, imagen 1 de 1
    • Remove the white cover carefully.
    • Using the pair of tweezers, unhook where the battery is held onto.
    • You are going to need to pull the hook will a bit of force. As seen in the video.
    • Be careful!! Do not pull it too hard with the tweezers. You don't want to damage the hook where the battery is placed.
  4. Casio G-Shock GA110-1B Battery Replacement: paso 5, imagen 1 de 3 Casio G-Shock GA110-1B Battery Replacement: paso 5, imagen 2 de 3 Casio G-Shock GA110-1B Battery Replacement: paso 5, imagen 3 de 3
    • Use a pair of tweezers or your fingers to remove the battery from its place.
    • Remove the new battery from its packaging.
  5. Casio G-Shock GA110-1B Battery Replacement: paso 6, imagen 1 de 2 Casio G-Shock GA110-1B Battery Replacement: paso 6, imagen 2 de 2
    • Place the new battery where it belongs with your fingers. Hook it back onto the device to secure it in place.
    • Reattach the white cover onto the device.
  6. Casio G-Shock GA110-1B Battery Replacement: paso 7, imagen 1 de 3 Casio G-Shock GA110-1B Battery Replacement: paso 7, imagen 2 de 3 Casio G-Shock GA110-1B Battery Replacement: paso 7, imagen 3 de 3
    • Don't forget that the rubber goes 1st inside the watch before placing the metal cover.
    • Make sure that the metal cover is aligned with the watch and not upside down.
    • Put back the metal cover and screw in back the four screws using the Phillips #0 screwdriver.
    • After screwing in the four screws, flip the watch over. Push the button on the bottom left and the watch should turn on!
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 personas más completaron esta guía.
Hector Mejia
Miembro Desde 10/05/21
361 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 14
Ultimos 7 días: 86
Ultimos 30 días: 371
Todo El Tiempo: 4,752
