Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
In this guide, we will be completely tearing the phone down to remove the whole motherboard and replace it with a new one.
  1. Slide the slider on the back of the phone to the free position.
    • Slide the slider on the back of the phone to the free position.
  2. Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Pull the white battery tab upwards and remove the battery. Pull the white battery tab upwards and remove the battery.
    • Pull the white battery tab upwards and remove the battery.
  4. Remove the four 6mm Y0 screws from the corners of the device.
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Remove the four 5mm Y0 screws from the back of the device.
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Lastly, using your hands, separate the motherboard from its compartment.
    • Lastly, using your hands, separate the motherboard from its compartment.
Conclusión
Zack Almeida
Miembro Desde 24/10/18
389 Reputación
4 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 110
