Saltar al contenido principal
Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement
Qué necesitas
  1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: paso 2, imagen 1 de 1
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: paso 3, imagen 1 de 2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: paso 3, imagen 2 de 2
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Motherboard: paso 4, imagen 1 de 1
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: paso 5, imagen 1 de 1
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: paso 6, imagen 1 de 1
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: paso 7, imagen 1 de 1
    • Lastly, using your hands, separate the motherboard from its compartment.
  8. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: paso 8, imagen 1 de 3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: paso 8, imagen 2 de 3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: paso 8, imagen 3 de 3
    • Using a spudger, gently lift up the orange connector.
  9. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: paso 9, imagen 1 de 2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: paso 9, imagen 2 de 2
    • Flip over the motherboard
    • Using a spudger, lift up the small black connector and remove the camera.
Conclusión
Zack Almeida
Miembro Desde 10/24/18
392 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 150
