Introducción
After removing the battery and motherboard from your device you will be able to easily remove the head phone port by following the steps below
Qué necesitas
First, you are going to want to take out the two front screws from the device.
The screws are 4mm in length and require a Y0 bit to remove
In order to remove the audio port remove the two screws located on either side of the Audio receiver using the philips head J000 tip.
2 personas más completaron esta guía.
Un comentario
How do you view this? It says follow the steps below but it won't let you go below.
