Introducción
After removing the battery and motherboard from your device you will be able to simply remove the camera from the mother board after following the steps provided.
Qué necesitas
First, you are going to want to take out the two front screws from the device.
The screws are 4mm in length and require a Y0 bit to remove
In order to remove the camera, carefully disconnect the wires with the metal spudger.
Una persona más ha completado esta guía.
