Saltar al contenido principal
Casio G’zOne Commando 4G LTE Battery Replacement
Qué necesitas
  1. Casio G’zOne Commando 4G LTE Battery Replacement, Battery: paso 1, imagen 1 de 1
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Battery Replacement: paso 2, imagen 1 de 2 Casio G’zOne Commando 4G LTE Battery Replacement: paso 2, imagen 2 de 2
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
Conclusión
To install a new battery in your device, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Daniel Keenan
Miembro Desde 10/28/15
374 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-9, Miles Fall 2015 Miembro de UMass Dartmouth, Team 1-9, Miles Fall 2015
UMASSD-MILES-F15S1G9
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 730
