Saltar al contenido principal
Casio FX-115MS Battery Replacement
Qué necesitas
  1. Casio FX-115MS Battery Replacement, Back Plate: paso 1, imagen 1 de 1
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
  2. Casio FX-115MS Battery Replacement: paso 2, imagen 1 de 3 Casio FX-115MS Battery Replacement: paso 2, imagen 2 de 3 Casio FX-115MS Battery Replacement: paso 2, imagen 3 de 3
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
  3. Casio FX-115MS Battery Replacement, Battery: paso 3, imagen 1 de 2 Casio FX-115MS Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
Conclusión
5 personas más completaron esta guía.
Equipo
USF Tampa, Team 2-2, Nance Fall 2016 Miembro de USF Tampa, Team 2-2, Nance Fall 2016
USFT-NANCE-F16S2G2
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 18
Ultimos 30 días: 94
Todo El Tiempo: 6,506
