Introducción
This guide is a step-by-step process on how to replace the zoom lens on a Casio Exilim EX-Z850 camera. This will help you replace it if it is broken or damaged, and there are no special skills required for this project.
Qué necesitas
Remove the frame on the back side of the camera where the LCD screen was.
With the screwdriver, remove the two screws connecting the frame with the camera
Slowly pry off the frame from the camera
After removing the frame a plastic piece with two yellow button connections should fall off.
To put the Casio Exilim EX-Z850 camera back together, reserve the instructions to follow them in a backward manner.
2 personas más completaron esta guía.
