Saltar al contenido principal
Casio Exilim EX-Z850 Flash Assembly Replacement
Qué necesitas
  1. Casio Exilim EX-Z850 Flash Assembly Replacement, Flash Assembly: paso 1, imagen 1 de 1
    • Remove the four screws on the side of the speaker.
  2. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the two back screws on the bottom of the camera.
    • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly.
  3. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 3, imagen 1 de 1
    • Remove the four screws on the side opposite of the speaker.
  4. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 4, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 4, imagen 2 de 2
    • Once all screws have been removed, gently pry open bottom casing.
    • With tweezers, carefully remove ribbon from LCD screen.
    • Set bottom casing aside.
  5. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 5, imagen 1 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 5, imagen 2 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 5, imagen 3 de 3
    • Gently pry apart the top casing using tweezers.
    • Set the top casing aside.
  6. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 6, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 6, imagen 2 de 2
    • Use tweezers or prongs to pry the LCD screen off from the opening.
    • Note: The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
  7. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 7, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 7, imagen 2 de 2
    • Lift up the LCD screen, slowly move it to the other side.
  8. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 8, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 8, imagen 2 de 2
    • Pry off the LCD casing.
  9. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 9, imagen 1 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 9, imagen 2 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 9, imagen 3 de 3
    • Flip open the connector holding the ribbon.
    • Pull out the LCD screen with the ribbon from the camera.
  10. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 10, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 10, imagen 2 de 2
    • Remove two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
  11. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 11, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 11, imagen 2 de 2
    • On the front of the camera near the flash flip the connector holding the ribbon.
    • Remove the ribbon from the connector.
  12. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 12, imagen 1 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 12, imagen 2 de 3 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 12, imagen 3 de 3
    • Carefully remove the L shaped frame from the camera.
    • At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab.
    • Pop the frame off the bumps and tabs.
    • Note: There is a yellow and orange wire soldered onto the camera. Be careful not to pull them off.
  13. Casio Exilim EX-Z850 Flash Assembly Replacement: paso 13, imagen 1 de 2 Casio Exilim EX-Z850 Flash Assembly Replacement: paso 13, imagen 2 de 2
    • This is the flash assembly.
    • It needs to be removed with soldering points circled.
Conclusión
Una persona más ha completado esta guía.
Christian
Miembro Desde 01/28/11
320 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 4-38, Regan Winter 2011 Miembro de Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 2,705
