Introducción
If your Casio Exilim EX-Z80 is malfunctioning, you might need to replace the motherboard. Use this guide to do so. The motherboard controls all functioning of the camera so it must be in good condition in order for the camera to function properly.
A damaged motherboard can cause damage to connected devices. If your motherboard is overheating or shorting, do not attempt to power on and take appropriate precautions.
Make sure to power down your device before you begin.
Qué necesitas
Locate the battery compartment at the bottom of the camera.
With your thumb, gently press down on the compartment door and slide to the left to open.
Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
Open the battery compartment with your thumb or index finger.
Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
Lift the retaining flaps on the two ZIF connectors that secure the the lens ribbon cables to the motherboard.
Carefully pull the two ribbon cables from their sockets on the motherboard.
Turn the camera face up with the motherboard facing you.
At the bottom of the motherboard, there are four nodes. With the soldering iron, desolder the metal nodes to release the wires from the board.
With the soldering iron, desolder the three remaining nodes at the top of the motherboard.
Lift the two black retaining flaps on the ZIF connectors at the top of the motherboard.
