Saltar al contenido principal
Casio Exilim EX-Z80 LCD Screen Replacement
Qué necesitas
  1. Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: paso 1, imagen 1 de 3 Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: paso 1, imagen 2 de 3 Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: paso 1, imagen 3 de 3
    • Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
    • Open the battery compartment with your thumb or index finger.
    • Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
  2. Casio Exilim EX-Z80 LCD Screen Replacement: paso 2, imagen 1 de 3 Casio Exilim EX-Z80 LCD Screen Replacement: paso 2, imagen 2 de 3 Casio Exilim EX-Z80 LCD Screen Replacement: paso 2, imagen 3 de 3
    • Open the USB port tab.
    • Remove the single 2 mm silver screw using a Phillips #000 screwdriver.
  3. Casio Exilim EX-Z80 LCD Screen Replacement: paso 3, imagen 1 de 2 Casio Exilim EX-Z80 LCD Screen Replacement: paso 3, imagen 2 de 2
    • Remove the two 2 mm silver screws using a Phillips #000 screwdriver.
  4. Casio Exilim EX-Z80 LCD Screen Replacement: paso 4, imagen 1 de 2 Casio Exilim EX-Z80 LCD Screen Replacement: paso 4, imagen 2 de 2
    • Carefully remove the silver strip from left side. Open the battery cover and remove the metal strip with fingers by sliding it to the left.
  5. Casio Exilim EX-Z80 LCD Screen Replacement: paso 5, imagen 1 de 2 Casio Exilim EX-Z80 LCD Screen Replacement: paso 5, imagen 2 de 2
    • With the metal spudger, pry out the edge of the silver strip at the bottom right side of the camera.
    • Carefully remove the remaining part of the metal strip.
  6. Casio Exilim EX-Z80 LCD Screen Replacement: paso 6, imagen 1 de 2 Casio Exilim EX-Z80 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Remove the two 2 mm silver screws from the top corners of the camera using a Phillips #000 screwdriver.
    • Remove the three 2 mm screws from the left side using a Phillips #000 screwdriver.
  7. Casio Exilim EX-Z80 LCD Screen Replacement: paso 7, imagen 1 de 3 Casio Exilim EX-Z80 LCD Screen Replacement: paso 7, imagen 2 de 3 Casio Exilim EX-Z80 LCD Screen Replacement: paso 7, imagen 3 de 3
    • Using a small opening tool carefully release all lock tabs at the top and on the side of the camera from their locked position.
    • Using your hands, carefully separate the front and back panel from the camera.
  8. Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: paso 8, imagen 1 de 3 Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: paso 8, imagen 2 de 3 Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Gently flip the wide button cable up from the display cable.
    • Lift the brown retention flap on the display cable ZIF connector with tweezers or an ESD-safe tool.
    • Carefully pull the display cable from its connector.
  9. Casio Exilim EX-Z80 LCD Screen Replacement: paso 9, imagen 1 de 3 Casio Exilim EX-Z80 LCD Screen Replacement: paso 9, imagen 2 de 3 Casio Exilim EX-Z80 LCD Screen Replacement: paso 9, imagen 3 de 3
    • Pry the square holes that hold the LCD screen up with a metal spudger until you see the raised tabs in the metal holes.
    • Repeat the process with the holes around the four edges of the camera.
    • Insert the metal spudger into the gap of the metal case and pry up the LCD screen.
  10. Casio Exilim EX-Z80 LCD Screen Replacement: paso 10, imagen 1 de 3 Casio Exilim EX-Z80 LCD Screen Replacement: paso 10, imagen 2 de 3 Casio Exilim EX-Z80 LCD Screen Replacement: paso 10, imagen 3 de 3
    • Hold up the LCD screen in one hand and hold back the button cable with the other.
    • Don't let the LCD screen to fall back into the metal case and make sure the button cable does not get stuck on the display cable.
    • Pull on the LCD screen until the yellow display cable is fully out of the metal case.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 407
