Saltar al contenido principal
Casio Exilim EX-Z80 Back and Front Cover Replacement
Qué necesitas
  1. Casio Exilim EX-Z80 Back and Front Cover Replacement, Battery: paso 1, imagen 1 de 2 Casio Exilim EX-Z80 Back and Front Cover Replacement, Battery: paso 1, imagen 2 de 2
    • Locate the battery compartment at the bottom of the camera.
    • With your thumb, gently press down on the compartment door and slide to the left to open.
  2. Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 2, imagen 1 de 2 Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 2, imagen 2 de 2
    • With your index finger, gently pull back gray release lever for the battery to pop out.
    • Gently pull the battery out of the slot.
  3. Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: paso 3, imagen 1 de 3 Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: paso 3, imagen 2 de 3 Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: paso 3, imagen 3 de 3
    • Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
    • Open the battery compartment with your thumb or index finger.
    • Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
  4. Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 4, imagen 1 de 3 Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 4, imagen 2 de 3 Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 4, imagen 3 de 3
    • Open the USB port tab.
    • Remove the single 2 mm silver screw using a Phillips #000 screwdriver.
  5. Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 5, imagen 1 de 2 Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 5, imagen 2 de 2
    • Remove the two 2 mm silver screws using a Phillips #000 screwdriver.
  6. Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 6, imagen 1 de 2 Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 6, imagen 2 de 2
    • Carefully remove the silver strip from left side. Open the battery cover and remove the metal strip with fingers by sliding it to the left.
  7. Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 7, imagen 1 de 2 Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 7, imagen 2 de 2
    • With the metal spudger, pry out the edge of the silver strip at the bottom right side of the camera.
    • Carefully remove the remaining part of the metal strip.
  8. Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 8, imagen 1 de 2 Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 8, imagen 2 de 2
    • Remove the two 2 mm silver screws from the top corners of the camera using a Phillips #000 screwdriver.
    • Remove the three 2 mm screws from the left side using a Phillips #000 screwdriver.
  9. Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 9, imagen 1 de 3 Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 9, imagen 2 de 3 Casio Exilim EX-Z80 Back and Front Cover Replacement: paso 9, imagen 3 de 3
    • Using a small opening tool carefully release all lock tabs at the top and on the side of the camera from their locked position.
    • Using your hands, carefully separate the front and back panel from the camera.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 499
