Introducción
This guide will show you how to detach the lens assembly from the camera. You may have to repair or replace a cracked lens or one that won't retract.
Qué necesitas
Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
Una persona más ha completado esta guía.
