Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide shows how to remove the front case from the rest of the camera. You may have to do this to replace a damaged front cover or to access the inner parts of the camera.
Partes
No se especificaron partes.
  1. Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom. Locate 12 screws. Four on the left, four on the right, and four on the bottom.
    • Locate 12 screws. Four on the left, four on the right, and four on the bottom.
  2. Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
    • Using the #00 Phillips screwdriver, remove the four 3.66mm screws from the bottom outer case, and the eight 1.75mm screw from the sides of the case.
  3. Separate the front case from the body of the camera.
    • Separate the front case from the body of the camera.
Conclusión
Equipo
Cal Poly, Team 9-45, Regan Spring 2012 Miembro de Cal Poly, Team 9-45, Regan Spring 2012
CPSU-REGAN-S12S9G45
7 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 331
