Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide will show how to open the camera case so that the battery can be taken out and installed. The battery compartment is located on the bottom side of the camera.
  1. Slide battery compartment cover in the direction of the arrow located on the cover.
    • Slide battery compartment cover in the direction of the arrow located on the cover.
  2. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  3. The cover will spring open, revealing the battery compartment. Here is where you will remove or install the battery.
    • The cover will spring open, revealing the battery compartment. Here is where you will remove or install the battery.
Conclusión
3 personas más completaron esta guía.
Equipo
Cal Poly, Team 9-45, Regan Spring 2012 Miembro de Cal Poly, Team 9-45, Regan Spring 2012
CPSU-REGAN-S12S9G45
7 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 1,170
